# Page Not Found
The URL `integrate-ai/understand-ai-components/how-tools-work.md]` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [How tools work](https://docs.n8n.io/build/integrate-ai/understand-ai-components/how-tools-work.md)
- [How memory works](https://docs.n8n.io/build/integrate-ai/understand-ai-components/how-memory-works.md)
- [Understand AI components](https://docs.n8n.io/build/integrate-ai/understand-ai-components.md)
- [What chains do](https://docs.n8n.io/build/integrate-ai/understand-ai-components/what-chains-do.md)
- [What agents do](https://docs.n8n.io/build/integrate-ai/understand-ai-components/what-agents-do.md)
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://docs.n8n.io/build/integrate-ai/understand-ai-components/how-tools-work.md?ask=<question>&goal=<user_goal>
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/build/integrate-ai/understand-ai-components/how-tools-work.md`).
